Old 12-09-2012, 10:53 AM
nikster's Avatar
nikster nikster is offline
Default Rubber blade -thingie?
Lot of snow blade talk recently. Thought I'd throw this out, don't know if its been covered or not?
Has anyone added a rubber scraper for the bottom of a snow blade?
Any info would be appreciated.
Worth it?
Do they exist, or does one fabricate it from a rubber thingie ?
If they exist where does one purchase it?
Thanks in advance,
NIK,
Old 12-09-2012, 11:10 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
I don't know if any one makes them to sell but guys i know that make them they make them out of belting from dirt cavator cut a strip and drill holes and make it wider then cutting edge so you can use cutting edge for a clamp over the belt. hope this helps
Old 12-09-2012, 11:40 AM
edw's Avatar
edw edw is offline
Default rubber blade thingy
I just cut a strip of rubber from a 4 ply tire and bolted behind the metal cutting edge. I used a sabre saw to make the cut it only took a few minutes.I got the tire free in the junk bin at a tire store.I did have to get longer bolts so overall cheap.It seems like will hold up well from what I have used it so far.
Ed Wells
Jeffersontown Ky
Old 12-09-2012, 12:20 PM
nikster's Avatar
Would this classify me as a dumpster diver?
NIK,
Old 12-09-2012, 04:13 PM
xtrememotorworks makes a plastic one:
http://www.xtrememotorworks.com/Part...w%20Blower.htm
Old 12-10-2012, 03:16 PM
nikster's Avatar
Thanks,
Price is right?
has ANYONE tried this set-up (plastic)? Are you satisfied?
Nik,
Old 12-15-2012, 05:23 PM
Flatbedford's Avatar
I wonder how the plastic holds up. I guess that at that price it would be considered an expendable item.
Steve,
Former multiple 149 owner.
Old 12-15-2012, 07:59 PM
cub149's Avatar
cub149 cub149 is offline
I just can't see that cutting into any ice under the snow at all. I can't imagine it would last long on concrete either. Seems like one good scraping is all it would handle. I may be wrong (it has happened once or twice in my lifetime :biggrin2) Just seems wrong. I guess if you have a perfect concrete drive and want to save it from scrathes it would be good
Would like to hear from someone that has used them though.
Chip T.
Drexel NC
Old 12-15-2012, 10:37 PM
gcbailey's Avatar
gcbailey gcbailey is offline
I know you can get thick plastic ones for skid steers used in parking lot cleaning, but they are $$$ may want to check on a skid steer attachment site.
Gary
Old 12-20-2012, 08:03 AM
steve59's Avatar
steve59 steve59 is offline
Default Rubber Cutting edge
I made one a few years back out of 1/2" thick rubber to prevent scratches on my asphalt driveway. I wasn't to impressed with it because you have to plow very slowly to keep it from vibrating.
Chug a lug a luggin’ 5 miles an hour
On my International Harvester
