Old 12-04-2012, 04:11 PM
Daddysignman's Avatar
Daddysignman Daddysignman is offline
Default Carb problem????
Hey guys i need some expertise and maybe a miracle...
My 1450 which i have not been able to get running (well), so i finally brought it to my buddies shop (he is a John Deere dealer). Anyways he through another carb on my tractor and she ran fine! So they want to sell me a carb for $325. well i would love to throw a new carb on, but i dont have the money to. So my question is: can i fix this carb? He said it is worn out and she is getting too much air in or something. Or should i try and find a used carb? if so where?
Also, on my coil the bottom nut is stripped and the nut will not stay on tight anymore. What can i do?
I appreciate all your help in advance.
1977 1450 Hydro -At the Shop! and a 582 Special on torn down on the bench. QA42A, 2 44 decks, snow blade, trailer.
Old 12-04-2012, 05:26 PM
Jfejedelem Jfejedelem is offline
It is hard to say without knowing more info, but I would guess that it is getting too much air around the throttle shaft? Which there is a couple of different fixes for it, but really need to know more.
Old 12-04-2012, 05:34 PM
teejk teejk is offline
google Kohler K321 carb and I think you'll find a replacement carb for about $100 with no exchange. I'm guessing it is a Walbro.
as long as you are at it, get a rebuild kit for yours and have some fun!!!
Old 12-04-2012, 05:53 PM
I think it's the main throttle flapper. It moves up and down.
Old 12-04-2012, 05:55 PM
$325 for a carb? Are you getting kissed with that? I had Vince O rebuild one for about $20.00
Old 12-04-2012, 06:20 PM
David a Calkins David a Calkins is offline
Default carb problem
try to see if its a carter or warbro ,if warbro,dont fool with it .and get a carter , 26 or 28 or number 30 ,look in side the bore of the carb ,and it should say one of the numbers listed ,if it has numbers in the 50s ,its a warbro .now if your carb is leaking around the throttle shaft ,it can be repaired ,with a bushing ,or sometimes with a plastic washer .there is a brake down ,how to repair this in the kohler manual .hope this helps .David
Old 12-04-2012, 06:35 PM
Yeah I thought 325 seemed a bit steep.
Old 12-04-2012, 07:07 PM
at that price it should come with more than a kiss...
Old 12-04-2012, 07:13 PM
cubfixer's Avatar
cubfixer cubfixer is offline
For that much, it ought to come with an included o-ring!
John
Old 12-04-2012, 09:27 PM
Sorry to say, your buddy would be putting the boots to you for $325
