What are you guys useing for oil in the winter months? This is my first year owning cubs and I have a 123 and a 147 that I'm going to be plowing with. The 123 has a 301 and the 147 has a 321.
Are they inside in a heated shop or garage?
If so, I'd run the SAE30 in them but if not you could drop down to a 10W30. I think is what Kohler calls for in cold weather. |
Thanks guys, they're kept inside an unheated garage. I was doing some reading last night on kohler K engines and it suggested either 5w20 or 5w30. I think I'm going to try the 5w30. In general it's not super cold here when it snows so, I think that should work ok. Right?
Here is what Kohler recommends............ Motor Oil
Thank you, that's what I was looking for.
Just remember using multi blends they tend to use oil and smoke. So check regularly.
Thanks for the info. I did'nt know that so, I'll check it often. I'm grateful for you guys and this site. I'm learning alot.
Thanks again. |
i run 15w40 in mine year round.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10: ![]() |
