Old 11-19-2012, 05:26 PM
2cubcadets 2cubcadets is offline
Default Carb leaking
I don't know if anyone has run across
this problem. But I had fuel coming out of
High speed needle and pouring into floor.
I took bowl off and removed needle ,seat
And checked float all good.I adjusted
Float tang put it back together still leaking
I removed carb and found vent hole on the
Opposite side of where seat is was stopped
Up this vent goes to air filter base on carb.
Old 11-19-2012, 06:09 PM
Sounds like it's time for a carb rebuild.
Old 11-19-2012, 06:36 PM
Default Carb
Yeah I just had it rebuilt but they didn't do a good job of cleaning carb. All that was wrong was the vent was stopped up, causing me this misery.
Old 11-20-2012, 10:29 AM
jeff967 jeff967 is offline
a plugged vent will drain the fuel big time
