I got this tractor and thrower in a barter, and I'm missing a few parts to make these to properly work.
I need to find a front pulley setup for the drive, and can I change pulley size to get more rpm's out of the auger? I'm missing the t handle for the chute adjustment, no biggie can just make that myself! The lift bar from the thrower to lift attachment on the tractor. I'm going to go through and clean it up replace what needs to be replaced and squirt some paint on it. I may upset a few people with how I paint it, but I look at it as i can just sand it down and repaint it if i sell it ever. Another question is, what are some ways of getting more power out of the Kohler to really get some snow throwin going on?
matt (TK) 1952 buick special 1971 cub cadet 147 hydrostatic 19?? simplicity stallion twin 7 (soon to be f/x racer) |
mcarlson,
I worked on one of these ( see thread on here) but it hasn't thrown a flake of snow yet ![]() I did make a handle for turning the chute. These seem to get lost real easy. Good luck with the restoration. Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
![]() Quote:
![]() A single stage thrower works fine if you keep the engine at WOT and the auger full. |
Jeff
That looks COLD. What is that white stuff your mowing? LOL ![]()
Hi Sam,
That was the half way point of a storm we got a couple years ago. The 125 and QA-42 worked great ![]() |
Jeff,
Since I haven't run one was just going by what I have heard. Regards, Chris
Jeff,
Nice action shot of the thrower in action. Yep, looks to be doing the job. Thanks for posting the snow picture. I see you have chains and weights on the tractor too, I am sure those are pretty much standard when running one of these front heavy units. Regards, Chris
![]() Quote:
The single stage snow thrower works very well if used properly. WOT to maximize auger speed and enough forward speed to keep the auger filled with snow. ( hydro's have the advantage here ). Since that picture was taken, I've upgraded to fluid filled tires and wheel weights ( plus chains are a must ). Some folks worry that the chains will mark up their blacktop but that only happens if you spin your tires excessively. Jeff |
