Old 11-11-2012, 03:44 PM
sandreassi's Avatar
sandreassi sandreassi is offline
Default Help please!!!!
I started into replacing the cork gasket on my 782. I have everything apart down to the point I ready to take the pump off. But, now I can't get the pump off. I am using the how-to from Gerry (Kendall) Ide.
http://cubfaq.com/corkgasket.html
I am stuck on the part where he drops down the brake rod. I don't have brake rods and I can't get the metal arm to flop down and out of the way. I am stuck with a big mess right now.
Old 11-11-2012, 03:55 PM
Did you remove the linkage between the brake rockshaft and the puck itself? That's probably the only way that it'll tip out of the way.
Old 11-11-2012, 04:00 PM
sandreassi's Avatar
I removed a long bolt that was in the shaft. It had a square head on it. That gave it some play, but it won't tip out of the way. Should I be removing the suction line where it enters the rear end (bottom), or where it enters the pump (top)? I got the fitting loose on the rear end (bottom), but I can't budge the one on the pump end (top).
Old 11-11-2012, 04:08 PM
You won't be able to remove the suction line from the hydro pump until it is free of the transaxle. You need to remove the pushrod between the brake rockshaft and the puck so you can tip the rockshaft out of the way.
Old 11-11-2012, 05:14 PM
sandreassi's Avatar
Okay, thanks. So the rod that bolt was in should just slide in/out, and that will allow that brake mechanism to drop out of the way? Is there any reason for me to remove the suction line from the pump?
Old 11-11-2012, 05:22 PM
You probably don't need to remove the suction line from the pump. The rod in the brake linkage should come out if you remove the square-head bolt.
Old 11-11-2012, 06:45 PM
sandreassi's Avatar
I have that square headed bolt out, but that rod won't get out of the way. It moves a little, but not enough to allow that brake assembly to drop. Is there some sort of trick I am missing?
Old 11-11-2012, 08:29 PM
Hit it with some PB and a BFH and punch it will come out.
Old 11-11-2012, 09:48 PM
sandreassi's Avatar
Okay. Before I go all out on this, I want to make sure we're all talking about the same thing here. On the picture I have attached you can see the brake assembly on the right that I need to swing down and out of the way. Right now that's all the farther I can get it to go. My finger is pointing to the shaft that the bolt with the square head was in. The bolt passed through the brake assembly and into that shaft. Are we saying that the shaft should slide forward and through the threaded hole where the bolt was, or should it slide back towards the rear end?
Old 11-12-2012, 08:47 AM
Think you may want to down load the manual for the QL's and take a look at the trans section. I forgot that you have the cast rear in your tractor.
http://www.onlycubcadets.net/forum/s...ead.php?t=4644
