Old 11-06-2012, 12:35 PM
jr315 jr315 is offline
Default 782
is there anything I should look for this is my first 82 and I don't know much
Old 11-06-2012, 08:45 PM
I just got one this past summer and I am ignorant about them. I assume that you are looking for an IH one (earlier model). They would be red and the earlier models of them had red rearends and the later models had black rearends. The 782's had a hydraulic lift on them, which is very helpful on lifting implements (snow blowers, tillers, etc.) and some of them had dual hydraulics on them (port on the front, too)--more exclusive to the diesel ones, I believe and those would be marked as 782D. I missed a lot.....sorry and forgive me if I have given you any incorrect information, but that is what I believe to be true. Someone else please come to my rescue and provide more advice for our member....
Old 11-07-2012, 09:26 AM
i have the early model , with hydro lift
Old 11-07-2012, 09:59 AM
cub123's Avatar
cub123 cub123 is offline
One of the biggest things is if it has a series 1 kt17 in it, as they are known for having bad lubrication, especially on hills. Here are some serial numbers:
Series I were installed in Chassis Serial Numbers below 726124
Series II were installed in Chassis Serial Numbers above 726125
Other than that they don't have much that goes wrong other than the rag joints and a few other things. Got any pictures?
Old 11-07-2012, 11:38 AM
is there anything i can do to make the tractor better it has series 2 motor
Old 11-07-2012, 01:40 PM
ajgross ajgross is offline
Inactive Member
You could add a rear lift to it.
AJ
Old 11-07-2012, 02:06 PM
would a wide frame rear lift work?
Old 11-07-2012, 03:06 PM
cub123's Avatar
The series 2 is a good engine, As it has full pressure lubrication. Check the rag joints and replace if needed, change the oil and filters and you should be good to go.Great options are ag tires and weights, they make a world of difference with traction, and depends on what you want to do a cat.0 three point.
Old 11-07-2012, 05:03 PM
Inactive Member
Sort of. The lift bar and the way the yoke mounts are different for the x82 series. The lift bar on a 782 is straight and the yoke mounts with frankenstein bolts instead of a bar. Also if you have the aluminum rear end, you would need a special lower bracket.
AJ
Old 11-07-2012, 07:38 PM
so much stuff to learn , i have the red rear end , is that a good one?
