Old 11-03-2012, 06:57 PM
scgtguy's Avatar
scgtguy scgtguy is offline
Cool CC 1200 question
For you Cub guys ...
Looking into a 1200 to rebuild ... like the idea of the 3 speed manual trans but would like the hydrolics for the rear attachments etc.
Is there a way to fit hydrolics to a QL 1200 for implements ?
tks, Bryan
Old 11-04-2012, 08:07 AM
JayJay JayJay is offline
Default Hydraulics on a Gear Drive
scgtguy: I think you will have to add a pump to your system somehow. Some of the earlier narrow frames had a hydraulic option, then an electric with the Model 147; I've heard of people adding a power steering pump or another after-market pump.
Since you're running a gear drive, you would have to drive the pump from the engine, which would mean adding a pulley, probably to the rear of the crankshaft. The harder part, it seems to me, would be figuring out how to mount the pump to the engine block and brace it well enough to keep a drive belt aligned.
You've also got to make sure the direction of rotation for your pump is correct.
The modification you're contemplating is definitely in the "on-off" territory.
Old 11-04-2012, 04:57 PM
scgtguy's Avatar
Default 1200 hydrolics
JayJay,
tks for the ideas , would make a great GT eh ?
Bryan
Old 11-07-2012, 09:36 PM
bocephus1991's Avatar
If it were mine I would look for a 1250 or 1650 if I wanted a quietline with hyd. It could be done,think someone else on here has done it,would just be alot of work and alot of mods. I have a 1200 and love my old tractor,just think it would be simpler to do on a hydro drive. This is just my 2cents! Good luck if you decide to go ahead with it and would love to see your pics!..Brian
Brian
