Old 10-25-2012, 08:26 PM
mike912e mike912e is offline
Default Help with wheel application .
Just inherited a pair of Cub (?) wheels and they appear to be reversed from the wheels I have for my model 72 or 104 ; the valve stem is on the opposite side . The tires mounted on the rims are Firestone Town and Country 6-12 and they hold air . They do each have a part number stamped on the rim which is IH376189R91 . Anyone have an idea as to what model they fit ? Any help would be appreciated .
My model 72's major parts just got back from the powdercoaters and now the fun begins . This is my first restoration and first experience with powdercoating . So far it looks great, but then again I am biased !
Also experienced my first clutch problem on my 104 today . The clutch wouldn't release ! Pryed the plates away from the clutch with a thin putty knife and oiled the sliding parts and all is well now . Then the rototiller belt on my 2206 decided to come off and of course you have to disassemble half the pullies to get it all back together ! Also done ! Whew . Thank God for the wonderfull cool fall weather we're experiencing in Southeastern Pennsylvania . Makes working outside rather pleasant .
Mike
Old 10-27-2012, 07:53 PM
PaulS's Avatar
PaulS PaulS is offline
I broke a wheel on my 102. Bearing seized up and tore the hub. The replacement I got was the same in all respects except for the valve hole. I assumed that the replacement wheels had this feature. Only problem is It puts the valve stem on the inside of the rim as mounted.
