Old 10-23-2012, 08:40 PM
csliko csliko is offline
Default 582 Engine swap problem.
I inquired a 582 about 5 years ago but about a year ago the original briggs took a dump on me. So i found a Honda GX620 and bought it. It runs great its in the tractor but i have a vibration in the drive line because i made an adapter for the clutch driver. I am in need of someone that can machine an adapter if anyone has any information on a machine shop that i can contact would be greatly appreciated. Thanks Cody
Old 10-23-2012, 09:53 PM
Cody
This is the guy you need to contact, Jeff in Pa. He is a member on this site and does awesome work.
Mac
Old 10-23-2012, 10:00 PM
Cody
Mac
That's me
Need one of these?
I can make pretty much anything you need.
Old 10-23-2012, 10:16 PM
Jeff
I think what he needs is an adapter to bolt to the crank that will accept the 3 pin clutch driver sort of like the adapters that Mid West Super Cub sells for Kohlers and Vanguards but for a Honda. The pic is from there catalog but it should give you an idea.
Mac
Old 10-23-2012, 10:17 PM
Mac Thank you.
Jeff I sent you a P.M. and yes that looks like it but the flywheel only has 3 bolts.
Old 10-23-2012, 10:25 PM
Vince_o Vince_o is offline
Jeff
Check the other site there are drawings for the honda.
Old 10-23-2012, 10:28 PM
Originally Posted by csliko View Post
Mac Thank you.
I can make something similar to that
Old 10-23-2012, 10:29 PM
Originally Posted by Vince_o View Post
Jeff
PM please
Thanks Vince
Old 10-23-2012, 10:53 PM
Here are some pics during and after engine swap. Its not completely finished yet needs cover on mower deck sides cut to fit and tunnel cover installed.
Old 10-24-2012, 07:43 AM
You need some ductwork at the front to get the cooling air out the front grille, too. From what I've heard, those Honda V-twins run hot, so it needs all the help it can get.
