Old 10-22-2012, 10:10 AM
Default Question about generator
I'm familiar with the NF Cubs having a starter/generator that was run by a belt off the front of the engine, and I'm also aware that with the introduction of the quietline series a direct starter was introduced (on the flywheel) however, I do not know what replaced the generator (from the NFrames.) I've done some research and nothing seems to be coming up. What produces the current on the quietline series?
Thanks!
Old 10-22-2012, 10:16 AM
They have an alternator like current engines.
Old 10-22-2012, 07:56 PM
Tim.E's Avatar
Tim.E Tim.E is offline
Also known as a "stator". It is behind the flywheel. A pain to replace.
Old 10-23-2012, 03:28 PM
Thank you this helps clarify completely.
Old 10-24-2012, 12:02 PM
105_Tom's Avatar
105_Tom 105_Tom is offline
Yeah wierd to go from something as reliable as a S/G to a little stator that puts out around 28 volts AC and has to be rectified back to 12-14V. Oh well, they rarely go bad IME and the regulator/rectifier is easy to replace when it goes up...
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 10-24-2012, 02:16 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Progress marches on. Sometimes backwards, I agree!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-24-2012, 04:00 PM
Actually,
Stator/rect system charges@ lower rpms, is less costly to produce, is lighter weight and no moving parts to wear out.
what's not to like about that?
Old 10-24-2012, 04:19 PM
John
How is that backwards? The stator/alternator is higher output, and in my experience has been far more reliable than starter/generators. You're forgetting the mechanical voltage regulator for the S/G system, which needs periodic adjustment.
I have spent more time troubleshooting ONE S/G charging system problem than I have spent troubleshooting the more modern alternator/rectifier systems on tractors I have owned that were equipped with them...
Old 10-24-2012, 05:38 PM
I'll agree to that. That is one nice thing I like about my 12, 14, and 1650. Never had to work on the charging system. S/G's are nice too, but you do spend quite a bit more time looking for solutions.
Old 10-24-2012, 05:46 PM
Thanks everyone for the replies; I know more than I ever did about them, and I'm not complaining.
