First off I am new to the site. I aquired a 782D last october and its nothing but a headache. I had to replace the driveshaft and the flexible discs. I also did the starter upgrade right away being that winter was just around the corner. Anyways I was wondering if a cast rear end from a 682 would bolt right up to my 782d. The hydro seems to be really tight but I have been chasing a leak for quite some time now and some other issues with the rear end keep coming up.
Thanks for all your input! Jordan |
Jordan
![]() It will bolt up just fine.
Mr. Duke...Now, have we forgotten the thing that a 682 does NOT have? Hint: It makes lifting a tiller a PAIN!
-105___ Tiller |
The rearend will bolt up just fine as Duke says, but obviously the hydro pump will need to be swapped to the 782D's original unit.
Thanks for the quick responses. Would I need to swap over the hyrdo unit being the the diesels have auxiliary hydraulic ports?
Yes, but I was under the assumption that Jordan meant the whole trans/trans-axle assembly, due to pointing out his current hydro leaks.
-105___ Tiller |
If you do it you may want to re-seal it while before you put it in and checkout the trunion. Much easier to do it while it's out. Then you should be good for a LONG time. And as Matt and Conner pointed out you will need to use your pump. And welcome to OCC.
Because of hydraulic ports, and hydraulic lift.
-105___ Tiller |
So this should be a pretty simple process then correct? Forgive my ignorance but what would this trunion be? I will try and post some pictures of it sometime this week.
Yes and no...Depends on the person. ![]() Here's another link talking about the trunion... http://onlycubcadets.net/forum/showthread.php?t=12401
-105___ Tiller |
