Old 10-21-2012, 10:02 AM
samiam44 samiam44 is offline
Default Help: Broken hydro lift
Guys,
I have no ideas here- what goes wrong with the hydro lift. My tractor drives fine- so i assume the pump is fine?
Old 10-21-2012, 11:46 AM
JayJay JayJay is offline
Default Hytran Level?
SamIAm44: check the level of Hytran in your differential, it is possible you have enough fluid to operate the transmission, but not the lift.
By-the-way, I posted a lengthy response to your first posting, you might want to take a look at it.
Jeremiah
Old 10-21-2012, 12:36 PM
cubs-n-bxrs's Avatar
I would pop the tunnel cover and run the hydraulics up and down. You could possibly have a broken shear pin or something might have disconnected itself.
Old 10-21-2012, 11:43 PM
X2....
