Old 10-15-2012, 09:53 PM
mrcubcadet's Avatar
Default D640 Glow Plugs
Decided to replace the glow plugs in the ole' 1782 before snow. What do ya'll suggest?
-105___ Tiller
Old 10-15-2012, 10:50 PM
mrcubcadet's Avatar
Found some on Ebay, and Xtreme...But they are both for D600's. Anyone know if they take the same plugs?
-105___ Tiller
Old 10-15-2012, 11:37 PM
They are different. The D600 takes Kubota #15951-65512 but the D640 takes a #15694-65512. I would take one out and take it to NAPA or a good autoparts store to cross it over. The D600 ones are about $7 to $8 each.
Old 10-15-2012, 11:42 PM
mrcubcadet's Avatar
I did see the different part numbers, but I just figured that they would be the same pieces.
-105___ Tiller
Old 10-15-2012, 11:54 PM
red56turbo's Avatar
Kinda interesting that they take different glow plugs. Basically the same engine just different specs (bore, etc.). Gotta do the glowplug updates to my 782 and 1772. Never woulda guessed the plugs were different.
Josh
Diesel Cub Cadets...........
Old 10-15-2012, 11:58 PM
I didn't know either. I looked them up on Parts Tree. I need to do my D640 also so let us know how you make out.
Old 10-16-2012, 05:05 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
I need to do the same for my D-600 , also need to swap out the key switch.
Doug
Original , 100 , 125 , 582
Old 10-16-2012, 12:33 PM
j knight j knight is offline
Default 1772 glow plugs
If you go to the Cub Cadet Parts lookup and check the part number for the glow plugs.
You will find it is the same number in a Kubota parts lookup
If you go to a marine sales outlet for Kubota engines you will find the same part number only cheaper
This may work for the 1782 as well
The 15694-65510 was super to the 65512 for the 1772
Joe
Old 10-16-2012, 06:56 PM
I don't know. I looked at Parts Tree, Cub Cadet and Messicks and they show the D640 using the 15694-65512 for $63.20 and the D600 using 15951-65512 for $27.69. I need to call Kubota and see what's going on.
Old 10-16-2012, 09:39 PM
rwonder rwonder is offline
I got the glow plugs for my D600 (1572) from Rock Auto NGK brand #347 2031. Were very inexpensive, I think around $6.00 each.
