Old 10-14-2012, 09:57 PM
ccguy's Avatar
ccguy ccguy is offline
Default Squealing PTO Clutch
After replacing the two idler pulleys on the mule drive to my 1440, I've reduced the metal-to-metal squealing when my mower deck is in operation (shot bearings in pulleys). The remaining squealing/grinding is coming from the 18 year old PTO clutch at the point of engagement and disengagement. Are there any lube points on the clutch and if so, where? If not, can it be adjusted? If not, does that necessitate a new $200+ clutch? Everything works fine but the high-pitch metal-on-metal noise has got to go!
Much thanks in advance,
ccguy
Western MA
1994/1440
Old 10-15-2012, 06:02 AM
Your PTO clutch bearing may be failing.
Old 10-19-2012, 07:58 PM
ccguy's Avatar
Thanks Mike:
I replaced the entire clutch and the noise is gone! The clutch I replaced is 6 years old and looks like it's in good condition -- is there any way I can replace the bearings to the old unit and if so, any idea who sells the bearings?
ccguy
Western MA
1994-1440
Old 10-19-2012, 08:06 PM
EricR's Avatar
EricR EricR is offline
Originally Posted by ccguy View Post
Is there any way I can replace the bearings to the old unit and if so, any idea who sells the bearings?
ccguy
Western MA
1994-1440
ccguy, just do a little digging right here in the CCC/MTD Cub Cadet built Tractors (GT) section and you will find a bunch of information. My Dad and I replaced the bearing in his PTO clutch, (2084) and it is very easy but you may have to do a bunch of looking for the bearing. Hope that helps!
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 10-19-2012, 09:30 PM
ccguy's Avatar
Thanks EricR...I'm scanning now....
ccguy
Western MA
1994-1440
Old 10-20-2012, 06:53 AM
Any idea where you got the bearing for the 2084 clutch?
Old 10-21-2012, 09:01 AM
EricR's Avatar
Mike, lucky for us we have a place local that carries things just like this and many old things. The place is Milesburg auto electric and they just about have everything you could think of. Sorry I couldn't be more help!
Old 10-21-2012, 09:52 AM
PaulS's Avatar
PaulS PaulS is offline
That local shop that EricR referred to does have quite a stock of the old stuff or the bit unusual stuff. They can even get the voltage regulators needed on the old tractors. It is a relief to go to a store and they know what you are talking about. I'll look to see if I have the part number or the id of the bearing we used.
Old 10-21-2012, 12:00 PM
Thanks.
CC doesn't list a bearing for that clutch, just a pulley assembly w/bearing at over $100!
Old 10-21-2012, 02:56 PM
Gaden's Avatar
Gaden Gaden is offline
Just about any industrial supply or machine shop would have the bearing, when I replaced mine, I took it to a local shop here in St. Joe, Mo; Jamison Machine. The guy looked at the number imprinted on it, went in the back and returned with a new one, it took him about 30 seconds. It cost me less than 14 dollars.
