Old 10-12-2012, 07:53 PM
bja105 bja105 is offline
Default What parts interchange, 1x8/9 to quietline?
I will probably end up with three rough tractors next week. First is a 107 minus the engine that I'll take some parts off for my 147. Next is a 129 with transmission problems, that I had intended to take the engine off for my 86. The third is a 1650. It looks mostly there, but it is in two piles for now. The seller just got it and doesn't know what is wrong with it.
If the 1650's engine runs, can a quiet line engine be put in an 86 with a minimum of adaptation?
If the 1650's transmission and hydro lift work, can either or both be swapped into a 129?
I really wanted a gear shift tractor (the 86) with enough power for garden plowing. But, the idea of a 16 HP with Hydro lift is also appealing to me.
What are the possibilities here? If it take custom machine work or welding, I'll probably stick to my plan for the 12 hp 86.
Thanks
Jason
