Old 10-10-2012, 12:45 PM
324matt 324matt is offline
Default Anyone know where I can get a Hydro pump rebuilt?
Im restoring my Red 782, and want to have the hydro pump rebuilt while I have it apart. It IS the ported one. Its out of a 1980 Red 782.
Any thoughts, links, or comments would be GREAT.
Thanks!
Old 10-10-2012, 01:46 PM
red56turbo's Avatar
Just curious,
but what's wrong with the hydro? These hydros are bulletproof and usually last for a long time if well maintained. I myself have never been into a hydro, but some guys on here have rebuilt 'em themselves. Hopefully they will chime in. Another option would be to just swap out your hydro with another good ported hydro. Really all depends on what's going on with yours and what your budget is.
Josh
Diesel Cub Cadets...........
Old 10-10-2012, 01:54 PM
I actually just found this link.
http://www.sauer-danfoss.com/stellen...e/bln-9646.pdf
Old 10-10-2012, 03:26 PM
Are you having problems with it now? If not I'd just put a new cork gasket in it and maybe a set of axle seals while you have the rear out and run it.
Old 10-10-2012, 03:37 PM
I figure since I have it out, have it rebuilt. I dont know if it got Metal Shavings up in it or not. The rear end has alot of metal and chunks of metal in the bottom of it too.
Old 10-10-2012, 05:35 PM
Originally Posted by 324matt View Post
My goodness they recommend hydraulic fluid and type "F" ATF.
shame shame, not one mention of Hy guard er hytran Ha,LOL
whodathunk
Old 10-10-2012, 05:59 PM
here are some shots of the transmission. There is metal in the small hole behind the bearing, and I have a question. Should the cage on the bearing have the small crack in it like this one does? There is a piece of metal roughly that size in the botom of the rear end.
Does anyone know why this case has stampings on it?
And why has it been scribed?
would these indications be clues that it already been rebuilt?
Old 10-10-2012, 06:24 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Im not the expert in this forum but conventional wisdom on the hydro pump is, if it's not broken, don't fix it.
The valves, perhaps, the seals perhaps, but the rest of it rarely if ever seems to fail.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-10-2012, 07:24 PM
The crack is a retaining ring--normal
I don't think you can/want to pay for a rebuild, If parts were avail.
Unless they suffer a catastrophic failure, leave well enough alone.
Worry about a problem IF it happens would be my suggestion.
Then replace with a good used one.
But everyone has an opinion, nothing wrong with that
Old 10-10-2012, 07:59 PM
Ok guys, thanks for the help. If I should leave it alone, is there any way to flush it out? Without spraying HY-TRAN all over my garage or lawn?
