Old 10-09-2012, 10:52 AM
cubby102's Avatar
cubby102 cubby102 is offline
Default 105/125 snow blade problems
Ok guys, since the 102 is literally a pile of parts right now, the 125 is gonna be on snow duty this year. But I'm having a problem putting the blade on. It has the quick connect on the tractor but, I can't seem to get the pins on the blade undercarriage to line up with it. They are quite a ways off. Am I doing something wrong here or is there a different style undercarriage for the quick connect. I'm lost.
Old 10-09-2012, 12:17 PM
You have the right idea with the quick connect, but I believe that is for a wideframe because the brackets are welded to the outside of the subframe, and the pins are pointing out.
Old 10-09-2012, 12:19 PM
Yeah you've got a wide frame cub cadet subframe on a narrow frame tractor. You need a different subframe. The rest of the blade is the same.
The narrow frame subframe looks like this:
and sits on a narrow frame CC like this
Not a great pic, but you can see where the subframe sits outside the tractor frame (the white over the yellow).
Hope this helps.
Old 10-09-2012, 12:26 PM
cubby102's Avatar
I thought the narrow frame subframe went straight back. And the wide frame was curved in and bent up? I'm not tring to argue just tring to figure this thing out. It goes on my 102 with the mule drive. I also have awide frame one that looks way different. This one goes straight back like your first pic.
Old 10-09-2012, 01:30 PM
cubby102's Avatar
It looks just like this one with the exception of the front mounts... I'm a little confused
File Type: jpg $T2eC16dHJF8E9nnC8H5iBQ!DoeyqjQ~~60_35.JPG (8.2 KB, 132 views)
Old 10-09-2012, 02:31 PM
ajgross ajgross is offline
Inactive Member
I wonder if you have a earlier "Pin On" style of subframe and some one welded pins in the bolt holes. Either way, it looks like you need a different subframe. If you look at the pics of the QA subframe, you can see how the brackets have a bend to them. Yours doesn't.
AJ
Old 10-13-2012, 11:33 PM
Looks like some PO has monkeyed with that subframe. I have several where that has been the case. On one of my subframes, someone has welded the front mule drive carriage on it instead of the pins. It fits over the frankenstein bolts and actually goes on easily and holds well. Hope you get that worked out before the snow flies!
Old 10-14-2012, 08:12 AM
cubby102's Avatar
I got it figured out sorta. I threw the deck back on the 125. And put it away for winter. Bought a complete basket case 1250 with a moddified to fit cc36 (I think) and a 44 inch deck just for snow purposes. I'll figure out the 125 at some other time
