Hydro and rear axle.
What are the differences between these two models that are not obvious by looking at the outside of them? |
Reduction gear ratio is about it. The Supers use a different pump out put shaft and reduction gear to compensate for the larger tires.
I am having to learn a few things about the Cyclops even though I have several. This 2084 is a recent addition to the other standard size. |
The output shaft of the hydro pump/motor that goes into the trans has teeth on it that mesh with the reduction gear and they are different between the Supers and the GT's. Also the Super stuff is NLA don't know about the GT stuff. What are you trying to do?
Looks like if I wanted to settle for reduced road speed in the 2084, this would work okay? Thanks |
If you put the 1864 rear in the 2084 it would go faster. The Supers have lower gearing because of the bigger rear tires.
Yes, brain went dead. Thanks.
And have less torque, which may be a problem. I may be imagining things, but I thought I saw someone post about having that problem when using a GT rear on a super.
Matt
Think this is the post you are thinking about. http://www.onlycubcadets.net/forum/s...t=8457&page=10 It's the tractor Chip built into a "Sub Super". He is in the process of converting the rear to the Super gearing at the moment as far as I know.
Chip T. Drexel NC |
