This was on a gear drive tractor that I have been working on and I think it is a tiller belt guide. Although I think it is either on wrong or it is for a hydro? Can someone tell me if how it mounts differently or the right way. Also is it really necessary to have this since I am going to be using a tiller on this tractor?
IMG_0207.jpg I would think it would be facing down. Thanks |
Dad used a tiller on his 125 and never used something like that, and it always worked fine.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
There was one type made for gear-drive tractors and a slightly different one made for hydro's. The one you have looks to me like the correct one for a gear-drive. Yes. It should be facing down. However, I would remove it altogether if you are not running a tiller.
Tractor #1--1972 Model 149 with rear lift Tractor #2--1972 Model 149 with rear lift 1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch |
Thanks sharkyohio, but where exactly does it mount? On the axle or frame? I don't believe there is a place on the bottom of axle.
It mounts as in the pic you have shown.just turn it around.
Up to 534 and counting... I give up updating my profile! |
I really wonder how much the belt guides help. Dad has run his 129 and #2 tiller every year since 1974 without a guide and never has had an issue. I've been running my #2 with my 149 for the past five without and issue either. Makes one wonder.......
Josh Diesel Cub Cadets........... |
