Old 09-14-2012, 02:37 PM
SwampRatt-1977's Avatar
Default 147 question
my 147 has a 1989 k321 replacement engine heres the link to the carb it has just wondering what model carb this is so i can look up a carb kit.
http://www.partstree.com/parts/?lc=k...catalogs_25652
Old 09-14-2012, 05:40 PM
JayJay JayJay is offline
Default Reply to 147 Question
I believe the 14 HP takes a #30 carb (that is, 30mm diameter throat); the smaller engines employed a #26 --at least, I know my 149 uses a #30 Carter/Kohler carb.
Old 09-15-2012, 07:41 PM
well i figured out my carb is a wallbro 47-053-69 but i can locate a carb kit. is a Kohler #30 carb the same kit?
Old 09-15-2012, 08:03 PM
Tim.E's Avatar
Tim.E Tim.E is offline
No,Walbro and Carter (Kohler) do NOT use the same kit. If it was me,I would get a Kohler Carter #30 and rebuild it.I (and others also)do not like the Walbro carbs.
Old 09-16-2012, 05:29 PM
Default Vote for Replacement
I concur with TimE, many times, no matter what you do, the Walbro can't be salvaged. I wouldn't put a lot of money into it; save your money for a Carter/Kohler unit.
