I've been looking through all the threads and could not find anything sloely related, but my issue is that my brake pedal with connections has been completely dismantled. After researching the parts diagrams I see three parts attach to the pedal assembly, the spring switch, the lever brake, and the lever brake rod. the cub cadet site also states that three spring pins are required, lookin at the pedal assembly there are four holes for the spring pins. does anyone have a picture or can tell me what order the attachments go? what the corresponding holes are? and do i need four spring pins? any info woulf be great
one of them, keeps the shaft from sliding out of the frame
so end result i need four spring pins?
You should only need three...There are different holes in the clutch pedal rod for gear drive and hydro brake/clutch linkage since they both use the same pedal and frame.
OK, I think I understand it now, thank you all
Tractor #1--1972 Model 149 with rear lift Tractor #2--1972 Model 149 with rear lift 1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch |
Thank you sharky
