Old 09-03-2012, 07:14 PM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
Default PTO Clutch: Does this look okay?
This is my first time rebuilding a PTO clutch (for model 149). I followed the instructions in the service manual and I used the guage that came with the rebuild kit.
When I took the old PTO apart, it only had one spring plate. However, the kit came with two. So I put two. Is this okay?
I used the guage as instructed in the service manual.
Here's a shot of one of the inside springs. Does everything look okay with my reassembly?
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
Old 09-03-2012, 07:48 PM
Looks right to me.
Old 09-03-2012, 08:17 PM
105_Tom's Avatar
105_Tom 105_Tom is offline
ditto what Lew said...
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 10-19-2012, 10:51 AM
boodog boodog is offline
Default Manual PTOs -two flat springs vs single bent tip spring
Hi guys.
I am about to order the parts for the rebuild of my 149 PTO. It sounds like I have the same as what SharkyOhio found - one spring instead of two flat springs.
I find it interesting we both may have what appears to be a non-stock setup on our 149 PTOs.
I looked around and read somewhere that folks use the PTO rebuild kit (759-3490) which has one spring with the bent tips instead of the kit for the 149 (759-3489) because the double springs tend to slip (even with the spring retaining knobs that are on the 149 clutch pulley).
Does this sound familiar? Is it a common practice to rebuild the 149 PTO with the single bent tip spring instead of the two flat springs? Is it nonsense?
SharkyOhio - how did your PTO turn out?
Thanks
Vince N.
Old 10-19-2012, 01:39 PM
Yup, I think it's good too. Two nuts on the backside, all threads showing approx same amount-- should work good.
Old 10-19-2012, 05:40 PM
SharkyOhio's Avatar
Default PTO Update
I installed the PTO pictured above on my tractor, but I have not used it with a mowing deck or snow thrower yet. It seems to be working correctly with the release lever, but I always engage the clutch when I test drive the tractor with no deck or other implement attached.
I have not heard of the center spring plates slipping and the repair manual shows the two spring plate setup as the correct configuration for this type of PTO.
Old 10-19-2012, 08:31 PM
Looks good to me as well.
I have never had any trouble with the springs slipping.
Nice work SharkyOhio
Old 10-20-2012, 08:21 AM
ok, thanks guys, I will go ahead and get the 149 PTO rebuild kit
-Vince N.
Old 10-23-2012, 08:43 PM
I installed the correct PTO rebuild kit for the 149 (the one with two flat springs) and it works great!
Now I will turn my attention to getting my 44" mower deck working better ... and be on the look out for wheel weights and snow blade.
I love this CC...I even waxed it
Old 10-24-2012, 12:01 AM
AH, where's the pictures?
