Thread Tools
Display Modes
![]() ![]() Anyone know the secret to extracting these spawn of Satan spring clips that hold the front grille on, short of latching onto them with vise grips and yanking for all your worth? Arrrgh !!! |
I'm about to put some in so if you know how to install on a 107 that would be cool too.
1970 Cub Cadet 107 currently being restored. ![]() |
![]() Quote:
![]() Simply push in, twist 1/4 turn, and they pop right out!! I have even made them by wrapping spring wire around needle nose pliers. It even closely duplicates the original conical tapered shape!! ![]() |
CadPlans hit the nail on the head. From the backside, push the spring in slightly and turn the spring so the hook part unhooks from the plastic grill and you're done. No visegrips needed. These springs are notorious for not holding very well to the point where the grill falls out and you mow over the grill.
Josh Diesel Cub Cadets........... |
Ah, now it makes sense why the grills are often missing. I always thought they just got misplaced.
Web Developer - Need a website? Contact me. |
When I purchased my 147 in the spring the grille was (and still is) held in with washers and machine screws. My dad's 125 has a wire holding it on. Neither are the stock clips.
I've never mowed over a grill but I can see how it happens-- you wouldn't know that it fell off until you mowed it.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
So what your saying is i still have them clips holding the grill on in my puller.That i should do something different because one of these times there going to let go when where in a wheelie and run it over thanks for the info
Current tractor my son and i have 1991 wheelhorse 520h 60"deck 48"snow blower w/ onan 20 hp 1980 whelhorse b-82 need restore 1976 simplicity 7116 all restored waiting for a new motor (my sons tractor) 1967 sears super 12 (my sons tractor) 1972 Cub cadet 108 restored w/ complete motor rebuild 5 years ago |
![]() Quote:
![]() As far as the 1X8/1X9 series, the worst part is the heat from the mufflers and what the heat does to plastic grills. ![]() ![]() I've gotten quite a few with modified grill holders from romex wire to twine.
There are always alternatives!!
O.K., got it.
Apparently these are the originals and will just take some finesse (Something not really in my way of doing things) Thanks again guys ! ![]() |
