Old 08-25-2012, 09:06 PM
IT1450 IT1450 is offline
Default Cub cadet 1450 restoration
Hey guys, Im working on my first ever lawn tractor restoration. The canidate is my prized cub cadet 1450. I forgot to take picture of the teardown and the pictures of the painting is on my grandmas camera as she was over taking pictures when my dad and i were painting i'll post them later when I see her again.
Here's it before painting
Old 08-25-2012, 10:10 PM
Nice cubs! Good luck with your restoration.
Old 08-25-2012, 10:11 PM
cub1450's Avatar
cub1450 cub1450 is offline
x2
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 08-26-2012, 12:08 PM
cub1782's Avatar
cub1782 cub1782 is offline
I like the ol ford in the backround.
Logan Pfeiffer
1986 cub cadet 1606 w/ spring assist, cat 0
1974 cub cadet 149 sleeve hitch
1984 gravely 5665 professional
1979 gravely 8122
1979 gravely 8102
2000 Exmark lazer Z
1978 international 184
Proud to be a member of the FFA
Old 08-26-2012, 12:23 PM
Donovan M.'s Avatar
of course you do logan
Donovan:
62' Original-fenders
Old 08-26-2012, 02:05 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Congratulation for your find!
I just start restoring a 1650 myself and I notice you don't have the original front axle and knuckles assembly on your 1450, I just wish someone can tell you what model Cub this one come from. Your front end look higher (about 2 inch?) and I like those narrow 4.00x8 wheels! I try to find a NOS set like yours but I only found a set of NOS 5.38x 8 so my choice in tires is limited to Firestone 3 ribs or Vredestein 5 ribs V61.
You never know what kind of snake is hiding under a rock but trying to make everything functional is the first goal, cosmetic is the second one in my book. Look like there is a lot of good fellow’s on this forum sharing their knowledge and since they are all Cub cadet lover you can bet they are there to save one from the junkyard.
Wish you good luck
Old 08-27-2012, 05:37 AM
cdlong's Avatar
cdlong cdlong is offline
To set the record straight, that's a garden tractor, not a lawn tractor. Best of luck, I have 2-1450s. Just rebuilt the engine in one and purchased the second one. Looking forward to the pics! Looks like a narrow frame pulling front axle. Had one on my 122 puller pictured above left. Looks like the front end was raised instead of lowered.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 08-27-2012, 06:10 PM
He has a good reason, Fords rule
Wish you good luck
Thanks, Ive owned the tractor for 5 years and have been bugging my dad to let me paint it for 4 of them. Finally when my engine began smoking and my transmition lost almost all power my dad agreed to let me paint it and do a full restoration.
Originally Posted by cdlong View Post
To set the record straight, that's a garden tractor, not a lawn tractor. Best of luck, I have 2-1450s. Just rebuilt the engine in one and purchased the second one. Looking forward to the pics! Looks like a narrow frame pulling front axle. Had one on my 122. Looks like the spindles were raised instead of lowered.
The front axel is out of an old noma lawn tractor, It is put in so I can squeeze into a lower weight class for tractor pulling. plus the tractor is sitting high because the the only way the axel could fit into the tractor was to put it in upside down and turn the spindalls around.
Thanks, the 1450 is mine, and the 109 is my brothers it'll be his (my next) project.
Thanks the old 76 ford (it has a 79' grill ) is gonna be one of my next restoration projects.
Old 09-01-2012, 01:18 PM
hi guys i just got the engine rebilt and put in, i dumped a bit of gas in the spark plug hole and it fired over. My brother is attaching the tank as I speak hopefully it will start!!!
