Old 08-22-2012, 08:46 PM
Jimkin Jimkin is offline
Default Tiller pushing
I mounted a cub tiller with a 8 hp engine with 3 point hich to my 782 and it pushes it, The tractor will not maintain an even speed, it speeds up I have to slow it down. I would like to get it maintain a constant speed,
Old 08-22-2012, 08:59 PM
Merk Merk is offline
How hard is the soil?
Does it push more on first pass?
How deep are going on first pass?
Turfs or ag tires on the rear?
Project Uncle Dick
Cub Cadet 70
Old 08-22-2012, 09:28 PM
It does it in my garden and when breaking fresh turf
Old 08-22-2012, 10:56 PM
How fast is the engine on the tiller running?
Project Uncle Dick
Cub Cadet 70
Old 08-23-2012, 07:04 AM
gcbailey's Avatar
gcbailey gcbailey is offline
how much ballast do you have on the tractor? You're breaking fresh ground with the tiller? Around here everyone I've ever known has plowed 1st, tilled 2nd....
Gary
Old 08-23-2012, 08:59 AM
Leadslingingdaddy's Avatar
With a Hydro you are going to get the inherent "Push" that is why alot of users have gear drives for this type of application... I used a 1650 with a tiller that had both extensions and in hard ground it pushed also....Just learn how to work between forward speed and depth as you go for the first couple of paths as it gets much easier as you go....Also take a shallow swipe the first time out.... Lift as you get near the end so it is a smooth transition in and out of the garden....
Old 08-23-2012, 01:20 PM
Mike1450's Avatar
Mike1450 Mike1450 is offline
Are the Tine's on the correct way? I had a neighbor that always complained his tiller never worked good an always wanted to take off, one day when he was fighting it I walked over and noticed his was on wrong. Never complained after that
