Old 08-16-2012, 05:38 AM
save_old_iron's Avatar
save_old_iron save_old_iron is offline
Default External Brakes on a 104 ???
Can external brakes be transplanted to a 104 that currently has internal brakes ?
Could this be a strictly bolt on operation if the right donor parts are found ?
What model # tractor would be an acceptable donor ?
If you do not learn something new every day ... you are not paying attention !
Old 08-16-2012, 09:57 AM
cubby102's Avatar
cubby102 cubby102 is offline
we just put a external brake rear on my buddys 100, was a direct bolt on. and works just fine
Old 08-17-2012, 02:16 AM
Thanks Cubby,
are there certain model #'s that make acceptable donors for the parts needed ?
are there some models that just won't work ??
Old 08-17-2012, 10:04 AM
ksanders ksanders is offline
The axles and calipers should work from any external brake tractor. The center cast piece would have to be from a gear drive 108, 128, 1000, 1200 etc.
Preserving history... one Cub at a time.
Old 08-18-2012, 02:04 AM
KSanders,
thanks for the update. I do have calipers and discs donated to me by other locals. I'll have a chance to see if these cobble together into something promising. I may need a few arms to connect the calipers to the brake pedal.
Chuck
