Old 08-08-2012, 05:13 PM
Daniel.Donaldson Daniel.Donaldson is offline
Unhappy 126 Help
I was mowing grass the other day when I heard a big boom sound. I thought i hit something with the blades of the deck, so I went back to the house and cut off the engine so that I could look under the deck. I couldn't see anything wrong so I was going to continue cutting my grass but it wouldn't start. I have no Idea what could be wrong with it. the engine ran very well before this so i know it has to be electrical. I hooked up a battery charger to it to make sure the battery wasn't dead. any advice would be helpful!
Old 08-08-2012, 05:49 PM
Did something silly like the coil wire fall off of the spark plug/coil? Is it out of gas? (yeah I know it sounds silly but I've done it before.)
Good luck with getting it running again.
Old 08-08-2012, 06:02 PM
Nothing seems to be missing/broken. nothing happens when i try to start it. No sound of the starter/generator, no solenoid click, or anything
Old 08-08-2012, 07:56 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
Did the battery blow up I had this happen once. The only sign that it had was the cracked case.
Old 08-09-2012, 08:16 PM
David a Calkins David a Calkins is offline
Default 126 help
pull the spark plug ,and see the piston ,is going up and down ,that dont sound good
