Old 08-07-2012, 05:08 AM
save_old_iron's Avatar
save_old_iron save_old_iron is offline
Default Proper rear rim offset
for a 104 - anyone know the proper rear wheel rim offset ?
Now that the tractor is stripped down to bare bones, I noticed the two rear rims have different offsets - otherwise the same size - but definitely different offsets.
Thanks in advance.
Chuck
If you do not learn something new every day ... you are not paying attention !
Old 08-08-2012, 12:56 PM
jcsmith jcsmith is offline
Default rear wheel offset
save old iron ,
I have a 104 also, it has 23x8.50-12 tires. I think this size was an option on the 104. The rim is 12-7JA, part #387 840 R91. On the inside it is 2 1/8 " from wheel flange to rim. On the outside it is 5 1/2" from flange to rim.Those measurements are as close as I could get. This was the standard wheel on the 124, optional on the 104. Hope this helps. If you have the narrow wheels, hopefully someone will chime in.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 08-09-2012, 03:56 AM
Chris, thanks for the detailed info.
The one rim appears to be the 2 1/8" offset. The second rim has only a 1 1/2" offset from rim to flange. There appears to be plenty of clearance to the fender wells with either rim, so a replacement for either one should not be hard to come by.
Thanks again
Chuck
