Ok so the title says it all. Here is what i'm wanting to do. Put a 4" electric actuator attatched to the lift handle. So i'm thinking mount it about 6" up on the handle. So then I can push the button on the top of the handle to put it in float mode and control the up and down motion with the actuator. What do you think. Surely someone has done something similar to this.
Brent |
to the top
I'm not the most mechanically inclined individual, but I don't understand how you expect it to float with an acutator attached to it. Could you explain how you plan to accomplish this? Thanks.
Is there a reason why you don't want to just go full electric and change out the rockshaft? Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
If the button is pressed down the actuator can move the arm. The arms I am using for my sleeve hitch will be slotted allowing the blade to float even though the actuator will not be moving.
What is this rockshaft you speak of? Full electric sounds awesome to me. Brent |
The correct rockshaft for an electric lift doesn't have a handle, but a bracket that the actuator attaches to. Implements are then attached to this rockshaft via the bracket and the actuator, when employed "rocks" this shaft to lift or lower the equipment. Our sponsors usually have one of these rockshafts available and will allow you to correctly put this option on your cub to function as it should.
I get it. I didn't know they made a product for this. I figured I would have to custom make something. Thanks.
You can use your rockshaft and attach just the bracket after having cut it appropriately, but I have found that it is best just to replace your existing rockshaft with the correct one. The picture included has the rockshaft at the top and you can see the bracket on the LHS of the rockshaft.
Ok so the rock shaft is the long rod that the foot rests sit on, right? And that rock shaft was on a tractor with factory hydraulics?
Brent |
![]() Quote:
