Old 07-15-2012, 08:10 PM
sdk131 sdk131 is offline
Default Can't find thread - Kohler M18s that can Swap with KT17s?
Somewhere I had read a thread that included the necessary information about what Kohler Magnum 18s were direct swaps for the KT17 Series 1's. However, I can't seem to find it and I forgot to bookmark it. I have a 682 with a KT17 series 1 that is running for now, but I just found a gouged cylinder while giving her a thorough once-over (just purchased tractor a few weeks ago). It actually runs very well, so my plan is to just keep checking the oil...and run her till she pops. I have a hilly lot, so we'll see if the myth is true. I'm also consider ing the Vanguard 18 for a repower, but if I can find a magnum 18 in good shape for a bargain price I might go that route.
Does anyone have this information relating to the Magnum 18's?
Old 07-17-2012, 08:18 PM
capeless capeless is offline
I just came across an m18 from Craftsman GT6000, 80's early 90's. Let em know what you find. I'm looking for info as well.
Old 07-17-2012, 09:34 PM
All I have found so far is spec number 24506 should be a direct swap, minus wiring changes. Should be looking for a 1 1/8 output shaft for the PTO...
Old 07-18-2012, 06:50 AM
spec number 24506
YUP.....If you have that Cub Cadet Spec'd M-18, it will be a direct fit. There will be a minor wiring modification for the Ignition System.
Old 07-25-2016, 01:30 PM
wjduggan2000 wjduggan2000 is offline
Default M18 replacement for KT17
Hi, can you tell me or show me where the wiring changes are for a KT17 to M18 replacement? I'm doing this in a 782 and trying to figure out the best way to do this. Thank you
Old 07-25-2016, 01:42 PM
What is the Chassis Serial Number of the 782 you are working on...??
Old 07-25-2016, 06:10 PM
Roland will provide you with a schematic but in a nutshell you will just need to change the way you stop the motor by grounding the magneto, presently you remove power to the coil, very simple change the rest is a bolt in on a M18.
