Old 07-11-2012, 01:48 PM
SmithWorks SmithWorks is offline
Default 129 hydro issue
Well I completed restoration of my 129 and have a couple of issues. Hope y'all can help. My hydrostatic trans. leaks as I did not tear into it because it was fine prior to restoration (my luck!). But I know that's from the front seal, so I got that .However its always had issues with not staying on same speed. If I'm mowing and don't have my hand on the hydro.lever, it wants to take off full speed ahead. Any ideas?
Old 07-11-2012, 09:46 PM
cmatthew's Avatar
cmatthew cmatthew is offline
possibly a trunion repair is in need. use the search option. there has been alot of discussion on this and its a pretty easy fix.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 07-11-2012, 10:26 PM
You can tighten up the clamp at the bottom of the hydro lever.
Pull the tunnel cover, you will see how it works.
Old 07-12-2012, 06:55 AM
Go to the Service Manual and look at page 2-56.
