So I took the tin off as Paul showed up and found a 16 HP in it !!!!!!!!!!!!! So now what do I do with it?
Anyone know if I can solid mount this to an 82 plate and put it in a 582 frame? |
Vince, I am not familiar with a 582 but if it uses the same frame as the 682 & 782 you should be able to install a single cyl K series engine. The frame is built to accept the flat mount or the wide frame type. I put a 12hp in a 682 using a modified wide frame mount. It was a bolt in with no modifications to frame or engine mount. The driveshaft even fits, I don't remember having to change anything just plug it in and go.
Sweeet deal there! Post up on how it fits in the 582 when you get that far.
1782 smoker!!, 169 and parts 128 And a bunch of stuff that fits on the back of them LOL |
Vince , A 1282 has the single cylinder , but i am pretty sure they used some risers on the steel plate. I think MattG installed a single cylinder in his loader tractor , might look at his site.
Vince you lucky dog!!!!I am sure you will fit that baby in a 582.
You'll need the 1210/1211/1204/1282 etc. risers but they can be used with the QL rails.
I will be watching this Vince!
I plan on doing the same thing to one of mine! |
Crazy
After talking with Matt and a few other guys, Ive decided to go a differant route with this eng. |
What you up to Vince?!
I tell you but with what I do with it will pay for piston and rings for a mag and a command that stitting on the self.
