Old 07-08-2012, 09:41 AM
bkw3614 bkw3614 is offline
Default Quietline Snubber Height
I am about ready to re-install the engine on my 1250 nightmare. I have replaced the motor mounts and snubbers with the current OEM parts. The service manual asks for a clearance of .06" - .12" between the bottom of the snubber to the frame. Is this with the engine sitting on the engine cradle or for an unloaded engine cradle? With the style of motor mounts that I used, there is nearly a quarter inch of clearance. I need to get more shims to bring down this distance.
I might get this thing back together before fall.
Old 07-08-2012, 09:55 AM
That dimension is considered a "loaded" weight.
Old 07-09-2012, 03:54 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
That doesn't seem right. I used the after market ISO mounts on my 1250 and when I put it back together, the snubbers were within that range, so I left them alone. Are you sure you put the ISO mounts in right? My snubbers had shims under them. Did you forget to put in the shims?
