Old 07-02-2012, 06:59 PM
staylor1650's Avatar
staylor1650 staylor1650 is offline
Default steering gear box
i was looking around and seen something about changing the fluid in the steering gear box and my questions are
if this even applys to mine
1. how often does this need changed
2. what kind of fluid does it take
3. and how do i change it
this is on a 100
and i also changed the fluid in the rear end with 90w and somebody said that that will harm it and i should run hytran i didnt think it would matter since this thing has no hydraulics
thanks
75 Cub Cadet 1650
64 Cub 100
not cub but its yellow 62 allis chalmers b-10
Old 07-02-2012, 07:24 PM
mrcubcadet's Avatar
There isn't any fluid in the gearbox..Its grease-filled.
Even though there isn't any hydraulic cylinders being moved, there still is hydraulics on your tractor. The hydrostat pump, is basically a hydraulic motor..And it really needs hydraulic oil to run properly.
-105___ Tiller
Old 07-02-2012, 08:09 PM
Grease for the steering gear box. Hy-Tran or SAE 30 for the trans per the service manual. It is a gear trans not a hydro so gear oil won't kill it if that is what you put in it.
Old 07-02-2012, 09:24 PM
cmatthew's Avatar
cmatthew cmatthew is offline
X2 ^^^^^^^
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 07-02-2012, 11:15 PM
mrcubcadet's Avatar
..For some reason I didn't register that this thread was on a 100. Oops!
-105___ Tiller
Old 07-02-2012, 11:19 PM
so i just need to find the grease zerk on the steering box and 90w in the rear end wont hurt anything?
75 Cub Cadet 1650
64 Cub 100
Old 07-02-2012, 11:46 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
if the brake is internal it'll squeek and lock up if gear oil is used.
Doug
Original , 100 , 125 , 582
Old 07-03-2012, 02:24 PM
And the trans will probably be stiff and noisy when cold in the winter since it is designed for thinner oil.
If only to ensure correct function of the brake, I would use the correct fluid.
