Old 06-19-2012, 10:48 PM
Kelpie's Avatar
Kelpie Kelpie is offline
Default 70 Brake
I am installing a creeper drive and I noticed that the piston for the brake on my 70 does not go straight back, but angles up. Is it supposed to do that, or does that mean it's worn out? This is the tractor my Dad bought new and I know that the rear end has never been apart. I'm thinking about taking it apart for a cleaning and brake service.
Anyone have a pictures that show the brake setup? The ones in the service manual are not the best.
Thanks
1964 Model 70 that Dad bought new. Lights, fenders, creeper, 38 inch deck, Brinly plow, sleeve hitch, and lift assist.
Old 06-20-2012, 10:03 AM
You might have to replace clutch/brake return spring.
Old 06-20-2012, 11:00 AM
Kelpie's Avatar
The clutch return spring is fine. I am looking at the brake rod that pushes against the brake lining retainer inside the reduction housing. It does not push straight back into the housing, it angles up.
Old 06-20-2012, 12:21 PM
Pics wopuld help.
Old 06-20-2012, 01:49 PM
Kelpie's Avatar
Here's what I mean. The part circled in red doesn't seem to be right. It is not straight, it angles up.
Old 06-20-2012, 03:52 PM
jcsmith jcsmith is offline
Default 70 brake
I wonder if the ball is missing , or if the brake pucks are wore out. That piece should be kept level by the ball and adjusting screw. Hope it goes well.Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 06-20-2012, 05:33 PM
As has already been said, a picture of your tractor of the area in question would be extremely helpful.
Old 06-20-2012, 07:15 PM
PaulS's Avatar
PaulS PaulS is offline
I just checked my 102 and the little rod you circled goes straight into the rear end. I would assume the ball is missing.
Old 06-20-2012, 11:17 PM
Kelpie's Avatar
I went ahead and took it apart tonight. The ball bearing was there, but the brake lining retainer is stuck. It actually broke the end of the adjusting screw.
Looks like I'll be taking the rear end apart for cleaning and new brake linings.
In addition to getting new gaskets for the rear end and the o ring for the brake lining retainer, should I also get a seal for the reduction drive shaft?
Old 06-21-2012, 09:33 PM
Default reduction pinion shaft
I would say if the bearings feel good and the seal's not wet, leave it. Glad you found the brake lever problem. Have fun, Chris
