Old 06-11-2012, 08:35 PM
ngilson's Avatar
ngilson ngilson is offline
Default skinny or fat
what are the benefits of skinny ags vs wide ags
owner of
1970 cc 106,model 72
Old 06-11-2012, 08:48 PM
You get stuck faster ?
Old 06-11-2012, 08:49 PM
ngilson's Avatar
any one better for pulling
owner of
Old 06-11-2012, 09:48 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
been told 8's are better then 10's for pulling. but I've plowed with both and I like the 10.5's better
Doug
Original / IH 70 / IH 149 / IH 1650 / IH 582 / CCC 1772
Old 06-11-2012, 10:22 PM
Fat ones look cooler if that's at all on your mind
Old 06-11-2012, 10:36 PM
I agree with Diz!
Old 06-12-2012, 03:52 PM
cmatthew's Avatar
cmatthew cmatthew is offline
fatter for a wider surface area and better for bite. skinny is good for snow and mud.
Old 06-12-2012, 07:40 PM
Donovan M.'s Avatar
skinnys are good for moldboard plowing to.
Donovan:
62' Original-fenders
Old 06-12-2012, 09:45 PM
cmatthew's Avatar
skinny ags will work great pretty much anywhere same for the wide ags. and for pullin some will tell you one and others tell you different. its your preference and pulling style that decides the tire best for you.
Old 06-13-2012, 11:40 AM
Timbo1946 Timbo1946 is offline
Default Tire width
I haven't pull Cub, but I think it would be the same for larger tractor. I have found that narrower tires work better if track conditions are hard clay type surface. They tend to have higher pressures that bite the surface. In loose more gravel type tracks wider works well. I am not an expert mind you just my observations from watching my girl pull my antique farm tractors.
