Old 06-07-2012, 11:43 AM
OhioTractorGuy OhioTractorGuy is offline
Default 129 Floor board removal help
New to me 129 is in need of some small clean up and I want to repaint the footboards. However, the slotted screw heads are not coming off easily at all. Before I get out the dremel to cut off these stubborn guys, I'd like to know if the nuts on the underside are welded to the floorboard, or are they simply threaded to the screw? Thanks to all willing to answer a rookie question!
Old 06-07-2012, 11:55 AM
cub123's Avatar
cub123 cub123 is offline
Yes they are welded, and always seem to be a pain, sometimes you can take the sides off the heads and remove them with vice grips. Start soaking with PB blaster, or my favorite, Kroil.
Old 06-07-2012, 12:00 PM
cub1450's Avatar
cub1450 cub1450 is offline
Those nuts on the bottom are welded on .
And the best way I know to get those screws out is a Hand impact or a pair of needle nose vise grips and a lot of PB Blaster.
When you replace them I would just replace them with some grade 8 bolts so you don`t have to worry about it anymore .
The 129 is a great cub with lots of power have fun with it and
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 06-07-2012, 12:47 PM
Talking
Thanks for the super quick replies. I soaked them with PB yesterday, so I'll give them a try tonight or tomorrow.
I'll get some pics up after a quick pressure wash.
It has the 38" deck and the 42" snow thrower. Looking to use this, versus restore it, but I've been known to have issues with knowing when to stop making things look nice!
Old 06-07-2012, 01:49 PM
Ash_129 Ash_129 is offline
Then you are in good company here on OCC forum.
Cub Cadet 129
48" deck - grass mowing
38" deck - backup deck
42" front blade
Old 06-07-2012, 01:56 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
yeah a lot of us have that problem around here!!
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 06-07-2012, 02:24 PM
Flatbedford's Avatar
A member her suggested I use a small cold chisel to remove them. Put the it in the slot at as much an angle as possible and try tap them with a hammer to the left. Unfortunately, I got this tip after I used a grinder on one of them.
Steve,
Former multiple 149 owner.
Old 06-07-2012, 09:57 PM
I've never done it, but I thought I saw where someone recommended that you weld a nut to the top of them and get them out that way.....I would probably use this technique as a next to last technique, next to cutting them out.
Old 06-07-2012, 09:58 PM
Oh, that sounds like a good suggestion. I tried again tonight but they were still in there good. Shot some more PB on them and will try again with a chisel.
Old 06-07-2012, 10:08 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Talking
Oooh an opportunity to break out the welder...sweet...think I enjoy mine nearly as much as mu cubbie...
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
