I actually have searched the forum and can't find an answer so here I am. I need to move the tractor to a more convenient place to work on it. The operator manual states that "some tractors are equiped with a release lever on the right side of the frame near the cam stop". Well apparently this tractor doesn't have that lever. So, how can I move it without doing damage? Is there a way? I can't imagine why IH would make a tractor that couldn't be move except under power. I am sure someone in this group has the answer. Thanks.
Yours will then have automatic relief valves. You can push or tow at a safe walking speed. You will be fine.
1200, 1450, Red 782 |
![]() Yours must have the automatic valves if you had the manual valves you would have to use the hydro release lever on the right hand side of the the tunnel cover near the fender. |
Yeah what they said, and
Dale 147-Restored___________________882 Diesel Hydro lift (not installed)___________44" Deck 48" Deck_______________________QA-42a/b Snowthrower Rear lift ________________________XMW cat-0 rear lift Model 2 tiller____________________12" cat-0 Brinly plow |
So, I gather this is nothing to worry about?
Decal1.JPG If it is of any help here is a photo of the sn plate. Plate1.JPG We will be out of town for a few days so I won't be moving the tractor until next week. Again thanks for the input. David |
Don't pull it fast or to far and you'll be ok.
Thanks Duke. I'll take it slow and easy. David
Good to hear David.
| Tags |
| hydrostatic release |
