Old 10-04-2009, 07:26 PM
gcbailey's Avatar
gcbailey gcbailey is offline
Default What can I get/do with my Original?
Now that I've got my Orig running decent, I'm getting bored just riding it around in circles I've got a deck, but the front edge is ate out on one side so... I was wondering what all is out there I can do with this thing so I can have an "excuse" to get it out more. My friend said it looks like you could put a rear PTO on it, is that possible/practical? I do have a pull cart from my GT2544, but other than that...
Gary
Old 10-04-2009, 07:58 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
personally, I love restoring things to the "N"th degree. I just found an original sitting in a lot with a bunch of junk, gotta stop by and make him an offer.
Everyone here in CT. thinks that they're junk is worth alot because they saw one on the internet, or on tv sell for big bucks.
To me it's worth it, because Im passionate about antiques...so I guess going further with yours depends on personal preference.
Old 10-04-2009, 08:06 PM
Merk Merk is offline
Put your Orginal to work.
This isn't an Orginal....it is a 70 that I just finish. I took it to a plow day and pulled a plow:
70 has only 5 hours on it when it went to a plow day. I was impress on how well it pulled my 10 inch Brinly plow.
Old 10-04-2009, 09:52 PM
gcbailey's Avatar
my problem is I don't have anywhere level enough to plow on my property. My grandpa keeps a 2 acre garden, but the Kub B takes care of it for now.
Don't get me wrong, I love to just go over everything in the garage over and over. There are still things I need to get tweaked, I just want an excuse to say I actually "need" to use it I'd like to find an old sweeper and a blade. The blade would be great, but I just don't know what all is out there for an original...
Gary
Old 10-04-2009, 10:46 PM
Well, I use my original for spraying weeds, pulling a roller, pulling a drag for the driveway, spring tooth, pulling the kids around in the wagon and a bunch of other stuff. I think cubs are as handy as a shirt with 2 pockets!
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 10-04-2009, 10:52 PM
67hydro's Avatar
67hydro 67hydro is offline
Lol randy, shirt with two pockets.Is that kinda like happier than a tornado in a trailer park!!
There are quite a few attachments you can use, and a lot of options you can add. Hydraulic lift, blade, plow, disc, trailer, loader, etc,......They did have a rear PTO, I'd love, love one just for cool factor, lol. But there was only a couple things it would run as it goes in a different direction than all other PTO driven equipment!
Jason
Jason Davis
Old 10-05-2009, 09:11 AM
gcbailey's Avatar
thanks for the suggestions... I've saw the guy with the danco loader on here... I would be in heaven with that, wouldn't have much of a yard left. I think my biggest problem is there is no one in southern WV southwest VA that has any old stuff. I've been told that everything listed above is specific to an original, stuff from a 70/100 won't work. Is that true? Does anyone have any sources for Original attachments? I can't really pick anything up, due to lack of truck...
Gary
Old 10-05-2009, 12:06 PM
RPalmer's Avatar
RPalmer RPalmer is offline
gcbailey,
I think you will have to look everywhere you can and have a fat check book.:biggrin2.gif:
Old 10-05-2009, 02:51 PM
ajgross ajgross is offline
Inactive Member
Gcbailey, If you look around, you should be able to find some attachemnts. it seem that PA is a super hot spot for anything CUB Cadet and I wouldn't think it would be that far from you. I would start by checking craigslist and e-bay or even some of the other Cub Cadet websites. I would post some links to them, but I found the hard way that this site doesn't allow you to even mention the names of them. Have fun in your quest. It may even make what you have more valuable to you.
AJ
Old 10-05-2009, 03:00 PM
gcbailey,
I have a suggestion, it won't get you a lot more seat time but personally I think it sounds like a fun project.
Find yourself an old generator (one that makes 110 or 220V) build a platform that will attach to the front of your Original, then build a shaft system to run the generator off the front of the crankshaft. Pawn shops are good sources for cheap used generators you can get one pretty cheap if the engine on it won't start or runs poorly.
Being that it is fall you could get yourself a lawn sweeper and clean up leaves around the neighborhood, and perhaps a nice core aerator to do your friends and neighbors yards with. It might just turn into a nice part time job...
