Old 05-11-2012, 05:52 PM
lagerboy's Avatar
lagerboy lagerboy is offline
Default Hour meter question
I am in the process of tearing down my Cub 169 to restore and rebuild. The hour meter is working, but the glass is fogged from the inside. Does anyone know if the glass and or retaining ring can be easily removed so I can replace the glass? Or should I be looking for a working hour meter with clean/clear glass?
Thanks
Cub Original,100, 102, 104, 126, 147, 1450 times 2, 1650, 800 and 169 times 2
1a & 2 IH tillers, #1, 2 & 4 carts, snow blade, Johnson Workhorse model 10 loader, Brinly 10" plow, multiple decks, etc.
Old 05-11-2012, 06:23 PM
Thanks
If that is the same meter that is on a Quietline and if the meter works, the lens is a easy fix. The "fog" is on the outside.
I had a non-working one to test on, so I experimented.
My first try was perfect. I used
1) car polishing compound (not rubbing compound)
2) the black bristle brush that comes with a Dremel kit
3) some gun cleaning patches
4) a 2500 rpm drill (speed is critical, not too fast, not too slow)
The brush is the one that has the bristles pointing away from the tool, not perpendicular to the shaft.
Use the brush and polishing compound first.
Then follow that with the brush driving the gun cleaning patch with compound.
Mine look like new now.
Takes 5 minutes.
Old 05-11-2012, 07:47 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Turtle Wax an a soft cloth. Turtle Wax is a polish, not just a wax. It's a gentle cleaner that works well for this kind of stuff.
Anything can be taken apart. It's the putting back together that's sometimes iffy.
My first experience with this (of many) was taking apart my dad's Big Ben windup clock one day when I was about 6. It seemed a likely candidate, given the plethora of screws and such to work on. Unfortunately this turned out to be a poor choice for exploration.
Good luck!
John
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 05-11-2012, 09:30 PM
Good luck!
John
John
I know this is off topic but when I was kid I took my fathers almost new push mower engine apart to see what made it run. He came home took one look at what I had done and said " You better be able to put that back together"
Old 05-11-2012, 09:51 PM
Mothers aluminium polish works well.
