Old 04-30-2012, 10:00 AM
ihnick's Avatar
ihnick ihnick is offline
Default clutch recomendations
ive got a project in mind with a 154 loboy motor in a 1x8 frame. i got the lowboy clutch parts but idk if i want to try rigging that clutch system in with the cub cadet pedal and stuff.
so im wondering what you guys would recomend for a clutch? maybe a red spring with a 6 pin driver and an aluminum disc would be enough or something in that order? i know its only 15 horse but i bet its gunna be torquey. thanks guys
Nick.
Old 04-30-2012, 10:18 AM
What does the LoBoy clutch look like?? - Pics?
Does the engine rotate the correct way?? -
Aluminum is "grabby"
What does that engine weigh!!??
Old 04-30-2012, 11:08 AM
You would have to mount the motor with the fan facing the back of the tractor or use the rear end housing out of it as they are the same as a cub cadet but the ring gear has been flipped and the pinion shaft is different to accommodate a clockwise turing motor.Have fun!!!
Up to 530 and counting...
Old 04-30-2012, 11:26 AM
red56turbo's Avatar
Sounds like a neat project. But Lew's right, gonna have to put the motor in backwards or do some swapping, flipping, etc........ The cadet sure would purr with that little four cylinder though.
Josh
Diesel Cub Cadets...........
Old 04-30-2012, 09:31 PM
Sam S.'s Avatar
Sam S. Sam S. is offline
I'm anxious to hear how this project goes! I also have a project in the works with transplanting a 4 cyl. out of a 154 lo-boy in a cadet. I think I might go the hydro route though (a little easier) and it's going into a 1440. Can't wait to see updates.
Sam,2-149,102-with creeper,102,125-parts,147,682,682-Cub Ca-table,1440 4cyl-(work in progress),3165,154 lo-boy with 3 cyl. diesel, Shed full of parts and accessories
Old 04-30-2012, 10:46 PM
SwampRatt-1977's Avatar
I have no idea about the clutch but i think i can speak for all of us when i say WE NEED MOCK-UP PICS lol
Old 04-30-2012, 11:11 PM
Dont let other people discourage you Nick. Its possible, may need to come up with some sort of reverser...add the lowboy drop axles to the rear end would be sweet. But then youd have three reverse and one forward...might be able to switch some stuff up on that.
Old 05-01-2012, 07:20 AM
maddog784's Avatar
Is it possible to just flip the differential around?
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 05-01-2012, 07:32 AM
Did the Farmall cub/lowboy not use the same transaxle as the cub?
Thinking they did, and the ring gear was on the other side.
I do know the Farmall 400 I have, has the ability to switch the ring gear for that application in the HiLo's that were built using those differentials.
