Old 04-30-2012, 09:10 AM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
Default Snow thrower questions
This is a QA 42A Snow Thrower. I believe it was previously used on an 82 series tractor. It had the 5/8 inch pulley. I plan to restore this unit and use it on a model 149.
Is this lift bracket factory original, or is it a PO modification?
This transfer shaft is showing some wear. Should it be replaced? I ask because the part is a bit pricey.
Transfer Shaft
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
Old 04-30-2012, 12:51 PM
maddog784's Avatar
That is not the original lift bracket - the originals are quite a bit shorter and don't bend out - I'm sure he bent those out to clear the side panels on his x82. I like these snow throwers - hard to beat and they do a good job.
Good luck!
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 04-30-2012, 01:33 PM
SharkyOhio's Avatar
Do you think it will work on my 149, or should I start looking for replacement?
Old 04-30-2012, 02:57 PM
Attachment 23899
Attachment 23900
Transfer Shaft
Might want to check the bearings there,and the shaft diameter,replace as necessary.
Old 04-30-2012, 03:36 PM
SharkyOhio's Avatar
Default Qa 42a
Here are some more photos;
Chain sprocket
Transfer shaft
Chain tensioner bracket
This is a major concern for me right now. Is this shaft supposed to move freely?
Old 04-30-2012, 04:56 PM
The chain sprocket and what you call the transfer shaft are both totally shot...someone with a mill and lathe could easily make a new shaft and modify an available sprocket to work.
Old 04-30-2012, 06:35 PM
bobcatboy bobcatboy is offline
ya i Just rebuilt me QA42A this fall. and $300 dollors later. I put on a new chain, adjustment piece, all new bearings, new flanges, two new sprockets. Your looking for parts go to CCspecalite.org they are very helpful. and if you need up close pictures i can do so.
Jimmy
1972 IH 129 ,QA42A snowblower, 44inch deck, and IHwindbreaker
Old 04-30-2012, 08:10 PM
SharkyOhio's Avatar
Default QA 42A Problems
The sprocket on the auger is welded on. I now have the bearings and collars off. The shaft (spindle) end is loose and will fall inside the auger tube, if you let it. I know this can't be correct.
How is the sprocket supposed to attach to the auger? If it is welded, what is the proper length of the spindle?
Old 04-30-2012, 08:38 PM
SharkyOhio's Avatar
Default Video Link QA 42A
Here is a link to a video of the problem area. Any help would be greatly appreciated.
http://www.youtube.com/watch?v=77EZdWDNisc
Old 04-30-2012, 08:49 PM
Attachment 23923
when i remade if you will my thrower i just weldedit to the auger its self. the large sprocket from CCspecalites fits in good.
Jimmy
