Old 04-29-2012, 02:34 PM
thadscub's Avatar
thadscub thadscub is offline
Default need help with 122
hi guys iam stumped when i rev the throittle the ovenor is not working as is it is supose too i have changed the spring and the placement of the spring
thanks thad
Old 04-29-2012, 02:49 PM
David a Calkins David a Calkins is offline
Default help with 122
when you said ,you changed the placement ,i don,t get that ,the spring will only go one way ,that will work
Old 04-29-2012, 02:51 PM
thadscub's Avatar
where the end that mounts in the governor arm moved it to a more sensitive hole
Old 04-29-2012, 07:12 PM
Here's where the governor spring is set on my 122
click for bigger pic
Might works perfectly in this position.
Old 04-29-2012, 08:59 PM
Governors seem to be a theme lately. If you can't get it lined out, you will probably have to pull the motor and look at replacing the governor components.
Old 04-29-2012, 09:02 PM
aarolar aarolar is offline
Just be sure you have it calibrated it properly CCW not CW.
