Old 04-29-2012, 09:24 AM
ronalddipietro ronalddipietro is offline
Default Mule Drive cub 107
Problem:..my cub EATS BELTS on ;the mule drive...I replace the two front pulleys with aftermrkt pulleys..NOT IH/Cub pulleys..would that make a abig differance?..the front left (facing the tractors grill) pulley hanger is very loose and wabbly...is that suppose to have alot of play in it??..I love the cub but cant afford belts at this rate...
Old 04-29-2012, 10:34 AM
Hey ronalddipietro
There shouldnt be a problem with the pulleys if you replaced with the right size.
I replaced mine with aftermarket and they are just fine.
The hanger shouldnt have a lot of slop in it.
Do you have the correct tension on the belt? To tight or to loose can cause problems.
I don't know if you have checked the manual for belt tension, but it might be a place to start.
