Old 04-26-2012, 08:02 PM
149 - 498944's Avatar
149 - 498944 149 - 498944 is offline
Default Mule Drive & Gear Box Installed
Been getting the 149 a little dirty since restoration. In preparation for the tiller I've refurbished the mule drive and rebuilt the gear box and got everything installed and working.
Mule Drive
Belt installed
The gear box
Cub Cadet 149 (Restoration Completed 2012)
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 04-26-2012, 08:24 PM
cub1450's Avatar
cub1450 cub1450 is offline
Great job!
Now you just need to restore the tiller.
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 04-26-2012, 08:29 PM
Merk Merk is offline
I would install the lower sleeve hitch bracket. The instructions have the owner/user using it. Having the extra support helps to keep the holes from getting oversize/oval shape.
The rest looks good.
Old 04-26-2012, 09:10 PM
Thanks Merk,
I didn't even realize that could be done - thanks for the heads-up. I'll have to get that installed.
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 04-26-2012, 09:13 PM
Yeap the tiller is next - and as she sits she doesn't turn.
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 04-26-2012, 09:19 PM
Sugarmaker's Avatar
AaaaHaaaa another tiller rebuild! Good I can watch The gear box and mule drive look real good! I need to put together a mule drive for my tiller.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 04-26-2012, 10:35 PM
machinehead323 machinehead323 is offline
That is looking great. I wish mine was that far along. For using the other bracket with the gear box is it the narrow one or the standard wide one you can use in conjunction?
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 04-26-2012, 10:58 PM
Looking good!
Old 04-27-2012, 05:50 AM
ajgross ajgross is offline
Inactive Member
I hate to be the bearer of bad news but you will also have to remove the drawbar, or at least i had to remove mine to get everything to fit.
AJ
Old 04-27-2012, 08:34 AM
I'm not sure about the bracket - I was going to ask Merk. I'm thinking it has to be wider. A picture would really help - anyone?
10-4 on the trailer hitch bracket - I assumed I'd have to remove it to install the tiller. Would be nice if you could leave it on thou.
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
