Old 04-25-2012, 06:14 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Default Inside my K301
Don't see any balance gears. Got a new pan gasket coming. Do I put it on dry or use a sealer. If so, what do you recommend?
Old 04-25-2012, 06:48 PM
I put my gaskets on dry, but if you do use some silicon, I would use it sparingly.
Old 04-25-2012, 07:00 PM
I used to use Permatex ultra gray for the pan gasket on my racecar for whatever that is worth.
Old 04-25-2012, 09:51 PM
If you are using a factory Cub Cadet gasket you shouldn't need any sealer.
All the ones i have used have been thick enough that they seal really well. Never had a problem with them.
Just my
Old 04-25-2012, 10:12 PM
bllwnkl's Avatar
I ordered the gasket from one of the sponsors, Cub Classics.
Old 04-26-2012, 06:42 AM
You should be good then, That's where i get mine
Old 04-26-2012, 04:11 PM
bllwnkl's Avatar
Thanks, all!
