Old 04-25-2012, 08:15 AM
drhntrrmw's Avatar
drhntrrmw drhntrrmw is offline
Default Creeper gear kicking out of low??
The creeper gear on my 72 ocationally kicks out of low gear.
I've had a few suggestions of the problem and possible fixes.
Has anyone else experienced this or have thoughts on the problem and possible fix??
Thanks as always!!
Rob
Old 04-25-2012, 04:59 PM
If the shift fork is worn, it may not go all the way into gear. If that's the case, you'll need to weld up and re-shape the fork to put back the material that has worn off.
