Old 04-21-2012, 09:50 PM
wmortenson wmortenson is offline
Default 122 tachometer
Put a new Equus tach. on the 122 today.
Will
proud owner of cub 122,128,70,100,and 682
Old 04-21-2012, 09:58 PM
Looking good!
Old 04-21-2012, 10:53 PM
silverthornethan silverthornethan is offline
looks sweet! i wish someone knew how to hook up my 5inch autometer tach on my 108 puller.
Old 04-21-2012, 11:19 PM
Default Silverthornethan
If your tach. Is like mine there is a wire that goes to the ground and one that you fuse with the wire that runs to the positive side of the coil so you have power to the tach when you turn the switch on. The pick wire from the tach. goes to the negative side of the coil or there is another wire that you can clamp on the plug wire. I found the pick up wire to the coil works better. Than there should be a setting for a one of two cylinder engine and the instruction bookle from your tach. should tell you how to set that.
Will
Old 04-21-2012, 11:49 PM
An auto tach will typically have settings for 4, 6, or 8 cylinders and therefore won't work in this application.
Old 04-22-2012, 09:38 AM
mickb72 mickb72 is offline
Would like some info on that tach. Model#,where did you get it? So that should work with a V twin with a mag? I wonder if the pickup wire would work off the kill wire on the V twin or would you have to use clamp on plug wire? Thanks Mike
Old 04-22-2012, 05:55 PM
Default Matt G
I have seen Autotachs on singles before but not sure what model they had.
Will
Old 04-22-2012, 05:57 PM
Default mickb72
I got the tach at O' riely's autoparts. Im not sure of the model or how you would hook it up to a twin. It is the same tach. that midwest super cub used to sell.
Will
Old 04-24-2012, 09:55 PM
my auto has the 4 6 and 8 settings but i was told somehow you can tune them to work on single cylinder
Old 04-25-2012, 11:48 AM
dbrenize dbrenize is offline
i even have a off brand one. and it only has these settings. i might put a small little tach on that has a single cyl setting. can some one post a link to one for me? it would be appretiated!
