Old 04-11-2012, 04:37 PM
red56turbo's Avatar
Default Anybody got any pics of rear pto linkage for a wide frame?
Just finished up getting the rearend bolted into the 800. Now I'm gonna run the linkage to the tunnel cover. Anybody have any pics of how the linkage runs? Also, where do you drill the holes in the tunnel cover? I know Lew's had NOS wideframe kits with the install directions and didn't know if he had a copy of em to pass on.
Thanks in advance for help or pics.
Josh
Diesel Cub Cadets...........
Old 04-11-2012, 07:05 PM
This is the outside of my 800
I had the cover off, there is no photo with it off because the 1/4" rod just swings down.
We want pictures!!
Old 04-11-2012, 09:52 PM
Josh, I can try and get you pics of my 128 with rear pto this weekend. It wouldn't be till Sunday night though I dont even know if it will help you or not...let me know.
Old 04-11-2012, 10:52 PM
red56turbo's Avatar
CadPlans,
Thanks for the pics. You wouldn't be able to take a few measurements for me would ya? How far up from the bottom and possible measurement of center holes for all three holes in regards to rear/top/bottom of tunnel cover. I'd be most gracious. Don't go out of your way, just when/if you get a chance. Also, when you move the lever forward, that engages the PTO, correct?
Ryan,
I'll keep ya posted if I need pics. I seem to be having a clearance issue with the battery cable hold down on the frame.
I'll try to snap a few pix tomorrow. I've got the fender pan off still cause it's tons easier to work on the linkage and get it figured out.
Josh
Old 04-12-2012, 01:56 PM
red56turbo's Avatar
I snapped a couple pics of the progress. The biggest thing I'm needing is where the lever gets placed in the tunnel cover. Once I get that drilled and placed, the linkage should fall into place. So measurements or even a straight side pic would give me a ballpark idea where to place it. Also added a creeper while the rearend was out. In the last pic, you can see the battery cable clip that is giving me clearance probs. Might just have to remove that.
Josh
Old 04-12-2012, 09:06 PM
Bolt the tunnel cover on the frame, position the pto handle so that the handle is vertical while the linkage will connect with the pto in neutral (out of gear).
The pto lever is pretty much centered in the cover side vertically.
That method would be better than dimensions. You need the handle to be vertical, if you use my dimension, the handle might not be straight up!!
Old 04-12-2012, 11:55 PM
red56turbo's Avatar
CadPlans,
I was playing around tonight with the tunnel cover on and the linkage acts like it's too short. This rear pto kit is out of a narrow frame and I was told they were the same. I measured the bent wire linkage and its 3 1/2 inches from end to end. Is yours the same length? Might have to do some modding or make my own. Thanks for all the help.
Josh
Old 04-13-2012, 06:24 AM
Yes, mine is way over 3 1/2".
Time to fab a rod, sorry I did not measure that rod.
Old 04-13-2012, 12:56 PM
red56turbo's Avatar
Yeah,
That's what I was wondering. Time to troubleshoot and try to get the right length. Anybody have one laying around for a wideframe they can measure???
Josh
